Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Transmission drain nut
Old 01-30-2006, 04:52 PM
007deuce's Avatar
007deuce
007deuce is offline
Default Transmission drain nut
I recently change my transmission oi and when I tighten the drain nut back on, I think I overtighten it to about 15ft/lb... Found out later from the manual that it should be only around 2 ft/lb.
My question is... How bad is this? Did I do any damage? What should I do now? Should I unscrew and tighten to 2 ft/lb?
Thanks in advance.
Old 01-30-2006, 04:56 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Default RE: Transmission drain nut
Doesn't sound grossly overtightened, just crack it loose and re torque it otherwise when it gets hot, it may be a different story. No big deal here, don't loose any sleep over it.
Old 01-30-2006, 06:02 PM
oldgeezer's Avatar
oldgeezer
oldgeezer is offline
Before you do anything, you might get a new o-ring from the Harley shop. The original one could have been damaged when you made it up and loosening it might cause the transmission to seep a bit. It will be a pain in the rear as you'll have to drain the transmission again and refill it but it might be worth it. Guess you could try to loosen it a bit and see what happens.
Old 01-30-2006, 07:32 PM
007deuce's Avatar
007deuce
007deuce is offline
ORIGINAL: TCSTD
Thanks! I had ride my bike quite a few times already... Total less than 100 miles since the transmission oil change.... Am I still okay? I guess I should take the nut out and have a good look... I got Syn 3 in it now... Might as well switch to Mobil 1 gear this time...
Old 01-30-2006, 07:34 PM
007deuce's Avatar
007deuce
007deuce is offline
ORIGINAL: oldgeezer
Thanks!... Yes, I went to dealer and bought a few new o-rings... Probably going with Mobil 1 75-90 this time since I am going through the trouble again.... Got syn 3 in it now.
Old 01-30-2006, 09:09 PM
007deuce's Avatar
007deuce
007deuce is offline
While I was getting new o-ring, Harley dealer sold me one of those loctite 565.
He told me to put that on all 3 drain nuts during oil changes.
Anyone use Loctite 565? Should I use it?
Thanks!
Old 02-09-2006, 12:03 AM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
ORIGINAL: 007deuce
Thanks!
I am trying to decide if I should use the loctite 565 on oil drain bolts as well. If you use them how difficult is it to remove them? Then do you have a hard time cleaning the threads to re-install? [sm=smiley25.gif] KB
Old 02-09-2006, 12:15 AM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
You really don't need locktite on the drain plugs, just torque them in and you'll be OK.
Old 02-09-2006, 06:07 PM
007deuce's Avatar
007deuce
007deuce is offline
Thanks!
I use some Loctite 565 when I change my oil last week... Looks like when I brought my bike back to dealer, they use some of those stuff...
Dealer told me Loctite 565 help to hold the nuts in place and prevent oil from sipping through.
Old 02-10-2006, 05:05 AM
ROADTRAIN's Avatar
ROADTRAIN
ROADTRAIN is offline
I understand that you could clean the threads of the drain nut but how do you clean threads in gearbox when oil is always going to be present. Wouldnt locktite need a clean surface to work propley. I would be just using the oring.
Quick Reply: Transmission drain nut
