What is the attraction of a six speed?
What is the attraction of a six speed transmission vs. a five speed? I have even seen discussions of a seven speed.
I have a five speed, and, IMHO, fifth needs to be geared higher. The only time it is really usable is for fuel economy while cruising--you never get there until 70 plus. The spread from 4th to fifth is pretty narrow.
RE: What is the attraction of a six speed?
Here's why I want a 6 speed (or higher gearing):
Am going out to Alpine and Marfa Texas in the spring. Going out there, we'll take the scenic route, so 5 speed is fine. Coming home, we will be haulin' azz in I-10, where the speed limit is 80. We usually go 5 over the speed limit. My Dyna does 70mph in 5th fine. 85 mph, sustained, for 2-3 hours, is gonna buzz me to death. if I had one more gear, I could cruise easily at 85mph
The six speed is nice but not a reason to trade or install one. Cost not worth it.
6th gear 3000 rpms = 80 mph.
On flat road no pull I run 6th all the time. If you want to take off real fast drop a gear and go.
I still enjoy riding my FB with 5 speed and it gets me everywere it ever did.
But the 6 speed on my RG is nice
The sixth gear is good as long as it`s an overdrive sixth.The new factory six is a 1:1 final drive ratio.The only way that it`s better (if you see it that way) is because they change the primary drive ratio which changes all the gear ratios as opposed to the five speeds which still end up at 1:1.You can get a better ratio by changing pulleys,your primary ratio or by installing a twistgear kit.I`ve got the twistgear and have no need for a six.Toby
ive got the o7 6 speed is a piece of crap ita a 1-1 final ratio with the primary and final drive geared up its a power robbing setup stay with your 5 unless u get a true overdrive with the 5 speed u can change your primary up or down to match your ridin style
