Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
When adjusting the primary chain, you are to adjust it at the tightest spot on the chain.
My question is, does the transmission need to be in first gear? Rotating the rear wheel while
in neutral, primary chain will not rotate. Thanks for the help.
