Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
DRAG & CCI has clear tubing, It comes In 16" length's and 25' rolls.
Or you could get A "Sterling Chromite ll" cable, they come with A clear Teflon covering.
I've used them A lot with no proublems.
Thanks for all the info! It turns out the local stealer is going to "warranty" it. I use that term loosely since he is going to make up a problem with the cable that won't raise any eyebrows.
