Tight Primary Chain
RE: Tight Primary Chain
ORIGINAL: rbabos
The whir sound is normal. If you pushed the ratchet up more than one click beyond it's normal spring setting you are asking for trouble . I've had several posts on how this thing works and should explain it all including why it makes a clank sound when on and off the throttle, as well as that rediculous claim of overtightening on it's own if correctly set up. Too much to type here, but search should find them. In the early posts I too assumed it was a piece of crap, but later investigation proved otherwise.
Ron
Ron
The slack should be 3/8-5/8 and although the impression is the chain is too tight it's not. Keep in mind it's not a rigid settup as you will still be able to push down on the top part of the chain and it will compress the spring in the shoe to give slack for a hot chain. The ratchet is only the first adjustment. Operational tension control is achieved from the spring system under the shoe. Much like the M6. Unless you force the ratchet up to the point where you are now compressing the shoe springs, over tightening cannot occur. The chain can never tighten from heat enough to use the full travel of the shoe springs. The tight feeling ,but not rigid chain loads pale in comparison as to what loads the crank sees when you get on the throttle.
Ron
Ron
ORIGINAL: mike_oh
When I installed it I made sure to have enough slack, about 1", and then released the tensioner and it did only move up one click. So I guess the noise is normal for this setup although it irritates me just enough that I might go back to the manual adjuster to get rid of the da## noise. I could live with it if I didn't think it might be screwing something else up by being too tight.
ORIGINAL: rbabos
Ron
Ron
