28 tooth comp sproket and chain
RE: 28 tooth comp sproket and chain
I hope so as when I need to replace mine I would like to know they can be had. Just for your info if I remember right the stock primary chain is an 82T so you would then need an 84T, I picked up a spare chain from Diamond without a problem sothe chain at least isan off the shelf item,the adjuster is also different since there is more free play in the chain, probably the best thing would be to contact Baker directly. Is that an R&R 155 your running? How long have you had it, I was just curious what the expected mileage would be as I have heard they are very durable. I saw a 203 made in Germany which fits in a stock frame I wonder if anyone knows much about it. I think the price was about 23K That would be a beast.
Hog Yild
05-10-2008 10:31 PM
Velocity1
03-06-2008 01:44 PM
