My rearend wobbles.????
RE: My rearend wobbles.????
Installed this on my '07 SG, which nixed the wobble:
www.ridestr8.com
https://www.hdforums.com/m_1957210/tm.htm
www.ridestr8.com
ORIGINAL: pistole
- why would a 'new' bike do this ?
Your engine is rubber mounted behind the gearbox, concentric with the swingarm pivot, to isolate vibration from you and the rest of the bike. There is another rubber mount at the front of the engine, and nearby there is a steel link that stops the front of the engine shifting sideways. There is a furtherlink doing the same job between the cylinder heads. So the motor is mounted at three points, but has only two of these stabilizer links.
When riding round a bend, thelateral forces on the rear wheel push that rear mount sideways, which is where the movement comes from. The solution is to add that 'missing' link, as TrueTrack call it.
Buell patented the third link several years ago and it is fitted to my Firebolt, also the latest Sportsters. It is a mystery that Harley don't fit them to all models with rubber mount engines!
There are at least four companies in the US that make similar stabilizers that I know of. I am just fitting a Trackula kit from TrueTrack to my bike and have another kit for my wife's Dyna.
I have no association with TrueTrack, they just providea goodexplanation for buying a rear stabilizer, also make a kit to fit my early Evo.
ORIGINAL: grbrown
ORIGINAL: iclick
I can only guess that the reason is money. The third link will cost HD another $20, 30, ??? on the assembly line, which adds up. The rear wobble isn't a safety issue, IMO, and HD probably feels most owners won't notice or care.
Put a glide-pro on my street glide nice now.The others are band-aids. www.glide-pro.com
