80 rotary top trans mainshaft tolerance??
80 rotary top trans (type with no mainshaft key) With the chain
sprocket on, how much in and out play is normal. I have .017 in
and out. I wanted to see how tight it would be before I put gasket
sealer in. So I put it together first. I also don't have 110 lbs of
torque on the nut yet either. The spacer that fits over the main
drive gear. Seems to be hitting the main drive gear, before the
transmission case, causing the slop in and out. I am no great
mechanic. But .017 seems like enough to cause a leak before long.
Thanks in advance to all that reply
old Shakey
09-29-2014 08:05 PM
JohnB445
01-20-2008 03:38 PM
