Primary case fluid
Primary case fluid
All right-----I screwed up
When they tell you 26 oz in the primary, they mean it. I was told to level the bike and fill it until you see oil at the bottom of the clutch. Well I found out you can put in 64 oz and just start to see it as I was told. It wasn't until I bought a service manual I found out there should be 26 oz that I fixed my problem.
Also I dumped the SYN3 out and put in the 20w/50. What a difference. If you’re having shifting problems, look at that.
Rusty
Rusty
