Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Is there a way to tell if the clutch is bad without disassembly? Lately it seems a little more sluggish than normal yet the RPM's sound normal. I really notice it when cruising and I decide to kick it down a gear or two and twist the throttle.
You might want to check the adjustment first. If it is out of adjustment you could "smoke it" trying to test it that way. Once you are sure it is in adjustment then check it like rbabos told you to. If it slips then it was shot anyway!!
