Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
changing out rear sprocket to 61T
Old 02-17-2005 | 03:39 PM
softtail3005's Avatar
softtail3005
Former Sponsor
Default changing out rear sprocket to 61T
Hello all,
On my 94 FXSTC I have the stock rear sprocket with 70 T. Note: the Trany sprocket is 32T. This gives a ratio of 3.15 engine rev per wheel turn.
Harley used a 61T rear pulley on non domestic bikes, giving a ratio of 2.94 revs per wheel turn. I am planning on replacing the 70 T with the 61 T to get better cruising speed at lower RPM's.
I know I will be giving up a little on low end acceleration.
Has anybody done something similar to this or have any suggestions.
Also I think that my 128 T belt will still work, but does anybody know for sure.
Thanks,
Jon
Old 02-17-2005 | 05:03 PM
billnourse's Avatar
billnourse
Default RE: changing out rear sprocket to 61T
I am thinking no, because I think I noticed in the HD catalog that there were two different belts for the Softails. 1 for domestic, and one for international. I'm not sure about this however.
Regards,
Bill
Old 02-17-2005 | 07:55 PM
Scout's Avatar
Scout
Do you have EFI or carb? I looked at a change, but decided against it due to take off speed, lugging, and potential clutch problems. I went with more inches instead.
Old 02-17-2005 | 09:31 PM
softtail3005
Former Sponsor
I have a carb, bike seems to have plenty of power, Andrews EV27 cam, Dyna 2000 Ignition, White Bros. pipes. I would think thar if Harley used the 61T pully on non domestic models ther should be no problem.
Also the 95-99 Harleys had a 2.93 ratio, using a 32 T Trans and 65T rear sprocket.
Old 02-17-2005 | 09:43 PM
Scout's Avatar
Scout
TC88, different engine, but you have the cams etc. Don't lug the engine and everything will be OK. In other words, race the **** out of her.
Old 02-17-2005 | 10:02 PM
pococj's Avatar
pococj
The belt might work, but it might take adjusting it to the end. If you are putting the stuff on yourself, you'll only lose a little time by trying it with the original belt. If it can't be adjusted, you've got a big job ahead of you pulling the swingarm, outer & inner primary, motor sprocket, alternator, clutch, etc.
Old 02-17-2005 | 10:27 PM
softtail3005
Former Sponsor
I picked up the 93 and 94 1340 cc parts catalog at the Harley Dealer today. If the book is correct.... Under HD Internationl only it lists the 40012-90 128T REAR BELT FOR THE HDI AND E1994 AUSTRALIA SOFTTAIL MODELS E-94-ALL.
It also lists the 40236-88A reat 61T sprocket for the same bike. This is the same belt as is listed for the domestic 1994 softtail.
I ordered the 61T sprocket a few minutes ago (great price from a HD dealer $179.00).
I will post if it works or if it does not. If it does it beats spending $2700.00 for aa 6 speed Trany.
Jon
Old 02-17-2005 | 11:47 PM
igniter's Avatar
igniter
Keep us posted, it would be interesting to see how it works for long rides. Mileage, passing power, etc.[sm=interesting.gif]
Old 02-18-2005 | 12:31 PM
softtail3005
Former Sponsor
Just got off the phone with Harley Davidson, project on hold.
Acording to them the 93/94 Parts Catalog for 1340 has some minor errors.
Before I go any further I have to actually do a count on the sprockets and
belt to see what I really have, then visit the local ABATE swap to see if I
can find what I need.
cycler
05-10-2017 07:50 AM
solorider75
02-04-2015 03:14 PM
dustyshovel
04-03-2014 05:25 PM
moose thecat
Wheels/Tires
10-06-2010 05:17 AM
Scarletthehog
Ironhead
17
04-19-2008 07:27 AM
Quick Reply: changing out rear sprocket to 61T
