Primary seal replacement
RE: Primary seal replacement
If you are careful, you don't need special tools. The outer/inner primaries and internals need to be removed, compensator nut/Clutch basket/primary chain.... There is a large snap ring holding the inner primary bearing in. I mention this because Baker has a seal/bearing kit that should stop repeated leaks.
The inner primary has seal (that is what I'm talkin about above). I don't know about an outer seal?
Invest in a service manual ($50), read the procedures, then make a decision. Oh yea, I wouldn't try removing a compensator nut without an air tool. I have guys tell me they did it and I'm sure they did....
Thanks Gunnert for the response. Have the manual, have air tools. Will read the manual, I have noticed the manual is not real clear on some of the jobs,pictures etc. Maybe its just me, been a car mechanic for 30 years! Who is Baker? I definitaly want to get a seal that does not leak! I bought this bike to ride, not work on.
There is also a seal for the jackshaft on the inner primary, you need to replace this too. I boughtthe seals from the stealer, I noticed that the new seals were double seals,whereas the old seals from the factory were single, I guess that harleyknew this was going to happen.I have done this on my glide, it is not hard, but you need to take your time and watch what you are doing. You will need something to lock the chain in place while you take the compensator and clutch nuts loose. Jim's makes a nice tool for this, it looks like a small set of steps. The clutch nut is left handed, keep this in mind. One of the nuts is an oddball size. Your best bet is to get the parts book along with the service manual.
Good luck.
Good luck.
It is definately do-able, especially if you have the manual and are a good wrench. A lift is needed.
Plan on at least 1/2 day start to finish, if it is the first time.
Removing the stator/rotor is the most aggrivating part. The HD tool works but you can do the same thing with a steering wheel puller and a piece of PVC pipe.
QuickSilver74
02-16-2011 10:53 PM
