Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
The bulk of what was in there was small fine shiny peices ,there was alot of this. The slivers seem to be soft and easy to bend, nothing really hard. I most likley will take it apart to see whats going on.
If you find you need a gear set, I have one from my 03 Ultra. I put in a Baker dd6 . Nothing wrong with this gear set. Let me know if you need one. I am guessing something is coming apart in yours. The shavings you describe seem a little large to me.
what kind of noises are you hearing? what is normal for tranny noises? are tranny noises rpm sensitive? any one have any answers. wacky55,06 FXSTI SE STageII SE211 cams VH BIG SHOTS STAGGERED PORTED AND POLISHED HEADS
