Stater 1996 FXSTC
Stater 1996 FXSTC
Help.
I need to remove the starter, I took all bolts out and the starter it is not coming off from inside of the primary case. Do I need to open the primary case and disconnet from inside or there is a way to disconnect from the outside. It looks like the shat goes inside the primary and it is not releasing.
Thank you, Ray
Thank you, Ray
80Sturgis
Electrical/Lighting/Alarm
03-05-2010 10:04 PM
