Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
80W140 Gear Oil for Primary?
Old 08-29-2024, 04:27 PM
702's Avatar
702
702 is offline
Received 5,790 Likes on 2,370 Posts
It's like an oil forum is needed here. You know, to keep oil questions in one place for easy reference.
The following 4 users liked this post by 702:
joenc (08-30-2024), Leimy (08-30-2024), Max Headflow (08-29-2024), MotoJockey (08-30-2024)
Old 08-29-2024, 05:21 PM
AMSOILman's Avatar
AMSOILman
AMSOILman is offline
New Member
Default RE:AMSOIL
Originally Posted by ricklee4570
I just bought a 2022 Street Bob with the 114 engine. The dealer did the 3 hole oil change and said they only use 80W140 oil in the Primary now. They said Harley stipulates all newer Harleys use only the gear oil in primary.
I looked at the bottle and it is not even a full synthetic, it is a synthetic-blend. I am coming from a 2012 Fat Boy and a 2011 Heritage Classic, where I only used Amsoil Primary oil in the primary.
Anyone know why Harley made the change?
AMSOIL has a 75w140 Severe Gear Oil and a Primary Case Oil for the wet clutch. Research - www.MyOil.Club
Old 08-30-2024, 12:03 AM
Leimy's Avatar
Leimy
Leimy is offline
I agree.
Wasn't there an oil thread that was closed?
Yet, it still pops up in many places
Old 08-30-2024, 12:07 AM
Leimy's Avatar
Leimy
Leimy is offline
The 80W145 is a good move for the primary. HD made a wide choice when they moved to it. If you read up on why HD did it will ease your concerns.
Why is simple better lube for the Job. F+ was ok is is a 50w. 80W145 is more along the line of a 20/50 engine oil. It protects better at both cold and extreme temperatures. Keep in mind Engine oil and Lubes like 80W145 are measured in different ways. When same method is used the 80W145 and 20/50 come out pretty much the same.
Howdy,
Where can I find that information?
I have been using 80W/140 for several years. I think it workds great. A old timer , both age and years of riding still says the 20w/50 for all 3 holes.
I'd like some facts?
Old 08-30-2024, 03:51 AM
gonemad's Avatar
gonemad
gonemad is online now
Received 7,309 Likes on 2,940 Posts
even the motor company, and their dealers can’t make up their minds.
so we like to deal in opinions instead.
Old 08-30-2024, 04:58 AM
Chris_G's Avatar
Chris_G
Chris_G is online now
Perhaps an Oil Thread would be appropriate 🤔
Leimy (08-30-2024)
Old 08-30-2024, 08:20 AM
bustert's Avatar
bustert
bustert is offline
if you have copper in the system, be very careful of the formulation. it will take out the stator if there is a breach in the insulation. the culprit is the sulfur additive used for EP.
DougYITBOS
09-16-2012 04:16 AM
Figstr
01-24-2012 12:01 PM
harleykruzer
09-15-2011 12:51 AM
Tropical Andy
06-06-2010 08:29 PM
187
10-02-2009 07:58 PM
Quick Reply: 80W140 Gear Oil for Primary?
