Must read regarding ESP extended warranty clutch repair
I'm guessing the key take-away from your post is to read and understand the contract before signing it.
What I did find interesting was that I could not find a copy of the Extended Service Plan (ESP) contract on the HD website to actually take a look at and read. I just found basic coverage details.
For instance, I see under primary drive, the following is covered:
- Chain Tensioner
- Chain Tensioner Anchor
- Plate
- Chain Tensioner Pad
- Chain Tensioner Plate
- Cover(s)
- Front Sprocket & Nut
- Grommet(s)
- Primary Chain
- Rear Sprocket
- Shaft Extension
- Sliding Cam
- Spacers
- Sprocket Cover
I'm not seeing clutch hub, bearing, etc as being covered either.
https://legacyh-d.com/extended-service-plan
NOTE: On the above website, the "Break System" is covered!
joofer (09-07-2022)
Received 4,898 Likes
Just went through my ESP (Purchased Feb 02/22.. (Its a Canadian one, but I'm sure they just substitute 'Harley Canada' for 'Harley USA' in the text.. In the 'not-covered' section, there is no mention of clutch or clutch plates. Although, they do add 'not limited to', which I guess means that they can decline repairs for pretty well anything they're not in the mood to cover.
joofer (09-07-2022)
strych9 (09-05-2022)
Nope. Not a clue.
- Chain Tensioner
- Plate
- Cover(s)
- Grommet(s)
- Primary Chain
- Rear Sprocket
- Shaft Extension
- Sliding Cam
- Spacers
- Sprocket Cover
PRINCES PER REPAIR WITHOUT THE H-D™ EXTENDED SERVICE PLAN*
WTF is a "prince"?Along with this:
NATIONWIDE REPAIR LOCATION ASSITANCE
What is "assitance"?
LQQK_OUT (09-16-2022)
goofyfoot2001
05-30-2014 08:55 AM
