Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Installing primary bearing Race trouble?
Old 08-22-2022, 06:20 PM
V Dubs's Avatar
V Dubs
V Dubs is offline
4th Gear
Default Installing primary bearing Race trouble?
Old 08-22-2022, 06:25 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 9,232 Likes on 4,931 Posts
Ok... what are you working on (model and year)?
Max Headflow (08-22-2022)
V Dubs's Avatar
V Dubs
V Dubs is offline
4th Gear
Installing a new S&S inner bearing race and having trouble getting it on the shaft in right position. I think I might have gotten one that has not been milled correctly. I can only get it to go on the shaft about 5/16 away form the sprocket shaft. Any thoughts?
Old 08-22-2022, 06:26 PM
V Dubs's Avatar
V Dubs
V Dubs is offline
4th Gear
Sorry 2006 road king S&S 56-5089
Old 08-22-2022, 06:29 PM
TSheff's Avatar
TSheff
TSheff is offline
Received 3,404 Likes on 1,579 Posts
There is a special tool for removal and installation. I strongly recommend using one.
Old 08-22-2022, 06:31 PM
V Dubs's Avatar
V Dubs
V Dubs is offline
4th Gear
Been using all the proper tools for the job!!
Old 08-22-2022, 06:42 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is online now
Received 5,830 Likes on 3,962 Posts
Old 08-22-2022, 06:44 PM
Max Headflow
Where is you main shaft seal on the MDG?
What model and year?
Old 08-22-2022, 06:46 PM
V Dubs's Avatar
V Dubs
V Dubs is offline
4th Gear
When mic the race I am getting about 24.98mm on the inboard side and 24.11mm on the out board side. I am no machinist and know that the race is supposed to be tapered but is that to much. The shaft is about 25.03mm
Old 08-22-2022, 06:52 PM
V Dubs's Avatar
V Dubs
V Dubs is offline
4th Gear
main seal is installed
2006 road king
Quick Reply: Installing primary bearing Race trouble?
