3rd gear slipping
My bike is in the shop now because of 3rd gear slipping. It only happens in 3rd gear. If you are easy on the gas it will not slip, once you twist more throttle it slips and jerks. I have an extended warranty on my 2019 Electra Glide Standard with only 11,000 miles. They haven't given me the results yet, but was told it was a worn bearing or a bad dog ring that holds the shifting fork. All in all, your transmission has to be taken apart. Harley wanted 1200.00 to fix, after finding out I had the extended warranty, I was quoted 50.00. You would think Harley would have a recall on this issue because it seems this is a common problem. You can still ride your bike, just get in the habit of skippiing 3rd gear when shifting. The engines pull great from 2nd to 4th, I even heard of a guy racing without 3rd gear,.....and was winning
Max Headflow. hey man, I was easy on the gears cause I like my bike. I wasn't ever trying to spin out on take off because i wanted my tires to last as long as possible. So either there is an issue with the way 3rd gear is built as having some poor engineering or they are just putting out some transmissions that are not passing quality control. Either way, I'm not the first person to have this problem, and it seems to be an ongoing problem. Maybe there are some defective Harley transmissions out being produced. Hell I don't know, but 3rd gear production needs some attention. Actually I think there should be some type of recall for this issue, or it should be a free to have the transmission fixed.
FWIW, it's not a common issue and shifting gears lightly could round the dogs just as bad as banging the gears. Buddy had the same problem with 3rd but only after building a 114 CVO into a 128. Still I know others with M8s and TCs (same tranny gears) that have many miles without issues.. Myself included. 111000 on a 107 TC and 47000 on a 17 RK M8. 3rd gear is a weak point. So were early 6 speed TC comps, early 5 speed tc cam chain tensioners, real early TC cam bearings and more. What about M8 oil pumps?..
darvinlowens03 (07-30-2022)
I’m getting some slipping in 3rd and 4th gear on my 13’ FLHTK (only when I get on it really hard) with 16k miles on it. I’m the 3rd owner. I changed all the fluids (and adjusted the clutch) on it when I purchased it earlier this year. My first thought is …slipping is caused by a worn out clutch? Seems like everyone else on here says it’s more than that?
curious how you make out with yours.
