Yet another Primary chain Question
Hey all, I'm new to this foum and did some looking beforeI asked.
What are some of the symptons of a primary that is to tight? I have heard the term the bike feels tight what am i looking for in feel of the bike ? I checked the chain and it was about 1/2 deflection cold
thanks you ahead of time for your help.
RE: Yet another Primary chain Question
Unless the chain is extremly over tight you really will not notice much just from the outside. It will acellerate wear on your complete primary drive system is why you do not want it to tight. To loose and the bike will try to "lash" or "jerk" when first giving throtal. If it gets to loose it will go to slapping the primary cover. Its not really rocket science to adjust one. You just need some give to the chain but do not want it sloppy. The 1/2 you have is close. 5/8-7/8 cold is what it calls for. Some times it seems one notch is to loose and the other to tight. I side to the loose side all things equal. I thank you will be fine as long as you were not straining to get that 1/2inch. I have never heard the term "feels tight" in ref to primary but would assume if chain was way over tight it would cause increased drag rolling the bike in nutral. [sm=confused06.gif]
azharleyrider86401
04-08-2011 05:43 PM
robster
08-05-2008 09:34 AM
Streetrunner
05-02-2007 11:59 PM
