Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Best primary chain tensioner
Old Yesterday, 07:47 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is online now
Received 6,040 Likes on 4,074 Posts
Originally Posted by Lostintennessee
Just yesterday I noticed white chunks flying around in my primary fluid. About 10k miles ago I changed from stock tensioner to a sohot hydraulic. About 2k miles ago I had a 124 built. I don't ride it hard..but 2 up most days. I'm going to receive the hayden in a few days and we'll see what happens. 2017 eg. I haven't removed the primary cover yet but I have a transparent derby. Also shifting sound/feel has changed.
Nothing wrong with the stock tensioner.. Early ones were supposedly ratcheting too tight but I suspect that some of it was misdiagnosis and the other was early TCs where the bike was run hard when cold.
Old Yesterday, 07:54 PM
Notgrownup's Avatar
Notgrownup
Notgrownup is offline
Received 7,171 Likes on 3,678 Posts
I put many thousands of miles on my 07 FLHTC. I also put one on my 14 Tri Glide. Will probably add one to my 21
Old Yesterday, 07:58 PM
Max Headflow
Do you have 124000 on any of them?
Old Yesterday, 08:01 PM
Notgrownup's Avatar
Notgrownup
. No, the 07 is gone to a friend and I believe it has about maybe 70000 . The 14 triglide only got about 15000 , I traded it in .
On my current 21 Tri Glide it seems that the stock one is doing ok but I only have 8000 miles on it. I probably will open it up this winter. Just to check but I may just go ahead and order a Hayden to Put in it.
Old Yesterday, 09:47 PM
Max Headflow
Well, I have 124000 on the stock tensioner 07 FLHTC. 20000 as a 96, 60000 as a stage 4 103 and 44000 as a 107, Still running the original. Been through a number of comps, 2 clutches, primary chain at about 100000.
Buddy has a 2012 pretty much stock road glide. We replaced the primary chain, tensioner and comp at 120000.
Old Yesterday, 11:24 PM
Lostintennessee's Avatar
Lostintennessee
Lostintennessee is offline
4th Gear
if the hayden craps out I will try the newer stock tensioner. I've heard good and bad about hayden but I think maybe it's due to installation error. (the bad)
Old Today, 12:13 AM
MotoJockey's Avatar
MotoJockey
MotoJockey is offline
Received 3,277 Likes on 1,343 Posts
I never even got my Hayden installed into my 14 SGS before I sent it back! The machining on it was crap. The shoe was sticking in the guides so bad it would stick down and not even pop up with the spring tension! If I turned that in for a project in my machining classes, I'd have gotten an "F" for sure. Some guys swear buy them. I liked the theory behind it, but I'll never put one in my bikes.......... YMMV.
I'm running the newer "C" version of the OEM tensioner with no issues for 120,000 miles.
Old Today, 12:21 AM
MotoJockey's Avatar
MotoJockey
Originally Posted by theheder
I just bought a Baker Driveline Armored Attitude Adjuster that I am planning to install with a new Baker Compensator very soon.
Armored Attitude Adjuster - BAKER Drivetrain
After the SE compensator and adjuster failed, I am hoping that with these parts I won't have to be in there again any time soon!
Hey ​​​​@theheder ...... got any update on this setup? Curious about Baker comp mostly, but interested about your opinion of the AAA as well......
Old Today, 05:28 AM
Notgrownup's Avatar
Notgrownup
When I had my 07 I had the ESP for 75000 miles , w went through 2 stock compensators and 1 screaming Eagle one and at around 60000 miles I decided to put a Baker Comp and a Hayden . At about 90000 miles I swapped the engine for a 103HO out of a 14 Street Glide, new Barnett clutch . The bike is still in that mode and still running great with the new owner. He has about 130000 miles on it now.
This is what I meant when I said it has about 70000 miles on it (the Hayden tensioner).
Seventy4blazer
06-06-2016 09:09 AM
JustDave71
11
06-12-2010 11:08 AM
Ramboamt
01-18-2009 10:41 PM
Paul32730
12-15-2007 10:43 PM
billbarket
56
09-11-2007 06:28 AM
Quick Reply: Best primary chain tensioner
