07 Clutch Cable Routing
This something for all owners of 07's to check. The way the clutch cable is routed it rubs on the rear brake line. The problem area is under the right side driver floor board. My friends RKC was wet in that area and after checking he found that the break line rubbed the clutch cable to the point that it started to leak oil. The oil was from the trans. The dealer is going to replace the clutch cable on Friday. I checked my 07 Ultra and it is also wet in that area. I will be going down to the dealer in the morning.
