5th gear moved installing seal
![](https://cimg8.ibsrv.net/gimg/www.hdforums.com-vbulletin/2000x1504/16524763373372234452211762125738_5de4f32044bb0e7241d22fc3ea380b0a6a22d77d.jpg)
![](https://cimg5.ibsrv.net/gimg/www.hdforums.com-vbulletin/2000x1504/16524764045271613570376307488995_9309416aed981802c55ec224093e4e771312404b.jpg)
OK what happened, how do I fix and what have I screwed up? Rebuilding my 04 FXST to 107 Darkhorse crank and Hillside top end. While I had the tranny laying on the table decided to change the 3 outside seals on the 5th gear since one had been leaking. Changed the main and Quad seal no problem and though I had the inner seal but somehow tapping the seal in with a 1 inch pvc and rubber hammer I have moved the 5th gear main shaft inboard. Not enough to start sprocket nut. Sooooo how bad have I screw up
![Icon Bricks](https://www.hdforums.com/forum/images/smilies/icon_bricks.gif)
Max Headflow (05-13-2022)
Dry shift the bike into 5th see if that pops it back out for you, you can do that by turning the mainshaft by hand while shifting.
