Overfilled Primary?
Overfilled Primary?
The service manual for my Softail calls for 26 oz. of oil in the primary which is an amount to just get to the bottom of the diaphragm spring. So, what harm is caused or what performance is degraded if the primary is overfilled, say to 1 qt.? One quart is only part way up on the bottom of the spring, so not far. Thanks.
(btw - I use Red Line MTL and change it every 5000 miles)
RE: Overfilled Primary?
As far as I can tell, an excessive amount of oil in the primary will effect clutch operation only. When a clutch is engaged oil is squeezed out from the plates in order to grip. If the level is excessive the extra fluid in the basket will slow this function down. You willfeel it immediately asslip.Doubtfull a slight variation in oil amount would have any effect that you would notice.
Ron
Ron
