Transmission main shaft leak
98 Road King SE 6 speed. I have transmission gear oil that seems to be coming through the main drive pulley splines. The shift shaft is dry and the main shaft seal doesn't appear to be leaking. Oil is on the back and front of the main drive pulley. I run 85/140 gear oil so I'm sure it isn't primary oil. Anyone have any ideas or come across this problem.
Bill Wetzel (05-13-2021)
Yankee Dog (05-12-2021)
Thank You for the reply Max. You are right after removing the lock plate the pulley nut was loose. This after carefully torqued to spec. Any idea what could cause the pulley nut to lose it's torque? I've done several of these SE 5 speed gearsets and never had this problem. I don't want to re-assemble without understanding what I may have done wrong. Any suggestions are highly appreciated.
Mine didn’t look worn either,but after loosening and replacing the front pulley 2x . I had to bite the bullet and replaced the main drive gear.
tony a
06-10-2013 03:12 AM
cjones55555
05-20-2013 05:50 AM
EastwoodFxwg
09-03-2010 08:11 AM
