M8 Clutch: Adjusted clutch, but then changed clutch cable to shorter. Do I need to re-adjust the clutch again?
On the M8's, they have that new, weird plastic clutch coupling assembly. So you can just swap out the clutch cable at that coupling up to the handlebars vs from the clutch itself up to the handlebars. BUT, does that mean that removable portion would necessitate clutch adjustment if it's swapped out?
I had the stock handlebars on with stock clutch cable. I adjusted the clutch during normal maintenance, at the actual clutch plate behind the derby cover. Then, new handlebars came in, so I swapped them out, and changed the "upper" portion of the clutch cable along with it, to a shorter one. Would I need to re-adjust the clutch for the new, shorter cable, or would the current clutch adjustment stay the same regardless of cable length?
Thanks!
Lunchboxx
08-17-2019 12:46 PM
