Transmission oil to engine
Hi
i have replace in mine 2014 FXDB oil pan (was demaged), i filled Up engine and trans oils and all was fine, after short ride i noticed weird sound on 4-5gear, i checked trans oil and it was empty... i checked engine oil and it was totally overfilled, i drained oils and filled Up again....same story after short ride :/
any idea?
is there any seal which i have to check?
thanks
any idea?
thanks
trying to clarify and rule out the crank seal post
fwiw
the pan is engine oil
the tranny is above it and has no pan per se
the tranny does drain through a non communicating hole in the oil pan
they do not share when working correctly
Any damage other than oil pan?
id remove pan and revisit my installation
i understand your issue is trans only
fwiw
fwiw
Don't really know for sure but on baggers, the oil drain hole for the tranny is in a different location than a Twin cam. On a Dyna, not sure. If they are the same, I'd expect that you damaged the pan gasket getting it on. Anyway you need to pull the pan back off and check the gasket fit.
Add,
You may want to check to make sure that the gasket surface on the passage is not damaged and it should be even with the pan gasket surface.
Add,
