Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Clutch question
Old 04-09-2020 | 06:44 PM
Max Headflow's Avatar
Max Headflow
Originally Posted by Whodeynate
Max,
i called Harley to check to see if one 99 for a twin cam would work but it won't. My buddy has a brand new entire clutch assembly and trans off a 99 twin cam. What I researched and what hd said were both the same outcome, 90-97 are all the same. Bummer it couldn't work but what can ya do?!? Lol! I appreciate the reply and suggestion!
Not sure who you talked to but if you have the whole clutch assembly including the basket, I'll bet it will fit.
Look at the instructions for SE clutch that I posted here..
https://www.hdforums.com/forum/prima...l#post19021670
It says that the SE clutch that fits all 5 speed twin cams can be made to work on a 94-97 with only an outer hub change. The outer hub is the same as the TC clutch hub.
Ask the guy if a 98 clutch works in a 94-97, it should. If so then a 99 will fit. The only issue might be if your buddies clutch is off a EFI TC, then it will have a 37 tooth sprocket on the basket. You can use it if you swap to a 24 tooth motor sprocket but it changes overall gearing from 3.15 to 3.30 (iirc)
Jag Jim
EVO
28
10-23-2018 12:02 PM
mrtom
Shovelhead
16
06-08-2013 07:23 PM
jmass
05-12-2010 10:58 AM
lou1
05-19-2008 03:00 PM
bigkylewhite
07-25-2006 01:32 PM
Quick Reply: Clutch question
