Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Using a M8 comp on a TC? Might be possible.
Old 12-19-2019 | 08:04 PM
Max Headflow's Avatar
Max Headflow
Default Using a M8 comp on a TC? Might be possible.
Here are some pics of an early SE twincam comp and M8 comp. TC on the left and M8 on the right. The spring pack is the same between the 2 bikes. It looks like the M8 comp might be able to fit a TC if spaced out some. Might have to clearance the cover. The SE come has about 20K on it and the M8 about 28K. Notice that the spokes and ramps are pretty worn on the TC and the spokes on the M8 look pretty good. HD widened the ramps on the cam. The M8 looks really good compared to the TC.
Old 12-20-2019 | 09:31 PM
EVOrider's Avatar
EVOrider
I’m interested as well.....should fit according to the pictures. Clearance could be a problem....maybe not.
Old 12-20-2019 | 09:33 PM
JustDave13's Avatar
JustDave13
Veteran: Marine Corp
Did you count the teeth? One looks bigger than the other.
Old 12-20-2019 | 09:37 PM
JustDave13's Avatar
JustDave13
In pic #2 I can see the inside diameter is wider, what does that mean?
Old 12-20-2019 | 09:55 PM
Max Headflow
Both are 34 teeth and use the same primary chain. In the first pic you can count the teeth.
Not sure what inside diameter?
Old 12-21-2019 | 09:49 AM
Zedbra's Avatar
Zedbra
My curiousity is perked here.
Old 12-21-2019 | 09:58 AM
Jackie Paper's Avatar
Jackie Paper
Think that big forge groove is oil valley?...Need to do some close measurements with a Dial caliper. Use a three pins about the diameter that fit the spockets for measurements. Since you are just measuring a comparison, should be simple enough. That spline should have no shake. If it does, it will loosen the lock bolt/nut.
Old 12-21-2019 | 10:12 AM
TriGeezer's Avatar
TriGeezer
I don’t mean to be questionable, but why would you want to do that, rather than something like a Baker?
Old 12-21-2019 | 10:35 AM
Max Headflow
It's an oil valley. The TC comp shown is a previous rev from the current comp used. The current comp used on TCs has a similar oil groove. Not sure what you need to measure other than sprocket alignment.. Not sure what you are measuring with 2 pins? Splines? The sprockets run the same chain. Splines on the cranks are the same. Both comps use the same nut / sleeve (sprocket retainer) and the same spring pack.
2016 comp
2017 comp
Old 12-21-2019 | 08:22 PM
Zedbra's Avatar
Zedbra
you're on here enough that you should have read that the Bakers are having issues of their own, with iffy customer service regarding the issues
smitty901 (12-25-2019)
Quick Reply: Using a M8 comp on a TC? Might be possible.
