Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Healtech Quick Shifter
Old 10-31-2019 | 09:58 PM
rodrocket's Avatar
rodrocket
Default Healtech Quick Shifter
Healtech Quick Shifter - has anyone tried these
Interested in peoples thoughts on this unit
https://www.healtech-electronics.com/products/iqse/
regards
Rod
Old 01-26-2022 | 06:45 PM
CVORoadKing2013's Avatar
CVORoadKing2013
I thought when I installed my USB charging port there was an unused connection up in that area but I would have to double check.
Old 01-27-2022 | 03:24 PM
djl's Avatar
djl
Looks like the market is primarly Euro bikes but it may be adaptable to a Harley. If it works, it is way cheaper than Pingle, which I run on an '05 FXSTD. The install instructions are not very clear and I couldn't tell how you activate shifting. Pingle has a bar mounted button for up/down shifts. If the OP gets one, I would like to know how it is installed and operated. Or if someone else here has installed on on a Harley, please chime in.
Old 01-27-2022 | 03:33 PM
hrdtail78's Avatar
hrdtail78
Veteran: Marine Corp
I think all it does is kill ignition for a certain amount of time . It states that default cut off time is 15ms. I wonder what the resolution of time they give us. Can we change this by ms or by 5ms increments?
Old 01-27-2022 | 05:53 PM
hardheaded's Avatar
hardheaded
All it seems to be is an electric switch on the shifter.
Old 01-28-2022 | 02:39 AM
Trvegiibz's Avatar
Trvegiibz
Hi guys, i'm running one on my dyna. We can change the cutting time by 5ms only.
Indeed it's only an ignition killer so the drivetrain is unloaded for a short period of time and gear can by change.
This is upshift only.
So far i tried different settings but it aint easy to find a good one without detonation and enough kill time for proper gear change but i'm not giving up.
So far it is very easy to use between 3/4/5/6 gear but 1/2/3 not so much, it's pretty violent on 1/2 and 2/3 sometimes the gear just jump and i'm in "fake neutral" so i'm not using it like that so much anymore.
But i'm pretty sure that it can be tuned properly!
Old 01-31-2022 | 07:53 PM
ThunderTruck's Avatar
ThunderTruck
regards
Rod
I've run it a couple seasons, personally I love it.
Regular shifting or when the RPM is right just a flick of the foot. True entertainment when doing some spirited riding.
Old 01-31-2022 | 09:07 PM
billib1954's Avatar
billib1954
I have one on my dyna. It's a lot of fun. Guy in Australia sells a nice kit with the load cell on a replacement shift rod. I had to fabricate a heel/toe shifter as my old arthritic leg couldn't generate enough force to pull up on the toe. I've had it for 3 or 4 years now.
Old 01-31-2022 | 10:27 PM
Trvegiibz's Avatar
Trvegiibz
For guys already running it, can you give us your settings? like kill delay kill times ect..
e11charlie
07-02-2020 06:48 AM
Skippy97
09-21-2012 12:02 PM
Crusher
10-04-2011 02:50 PM
JacktheBagger
10-02-2008 09:21 PM
Quick Reply: Healtech Quick Shifter
