Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
When was the oil changed? Is it possible that either it didn't get cleaned sufficiently when all that oil came out when the filter was changed? OR that the filter gasket got tweaked somehow and is leaking by? I would keep eye on oil level, clean it up real good to try to see where it is coming from. If it's coming from around filter put a new filter on it... if it was coming from somewhere else take it to dealer.
