Quick clutch question.
Hope this gets an answer before I get off work..
In a nut shell I had my clutch adjusted, because I didn't like the rest lease, since then I have said I have an issue.
I took it back to the person who adjusted it, said no issues, took it to someone else said the same thing.
Now this morning I started the bike in first gear with the clutch engaged and I had pull when it was turning over.
Now in my motorcross years I knew this was an issue.
I still say that I have an issue..
Thoughts
Thank you in advance
Thoughts
A couple of thoughts.
1. Don't start your bike in gear, especially when cold. The cold primary oil is thick and plates tend to stick together.
2. When you shift from neutral to 1st with the clutch pulled in, does the bike jump forward when warmed up?
3. When you release the clutch when in gear, how far from the handgrip iis the lever before the bike starts to move?
I suspect you are not used to Harleys or their cable actuated clutches and everything is fine since 2 different people inspected it and said it's normal.
Thoughts
Thoughts
I had kick start too, I could kick start in any gear, first being the best choice obviously. Those bikes never creeped when kick starting, I don't remember my sporty ever doing it either?
It took me a while, but in the searches I did I read something about the oil thickness and clutch plates sticking together being the issue.
Still to me it shouldn't do that.
I have seen some guys put automotive transmission fluid in the primary to keep the clutch plates from sticking when cold. The reason I never felt like trying that is because the compensator sprocket is banging back and forth constantly and the ramps could benefit from thicker oil than tranny fluid. I even remember seeing a YouTube video of a guy bragging about how great it was to run tranny fluid in the primary while he was in the process of replacing his worn out compensator sprocket and primary chain adjuster shoe.
