Clutch Cable Extender?
Hey all,
I adjusted my clutch this weekend and I noticed that my cable adjuster is pretty far apart. So I was thinking of installing one of those extenders (?) to lengthen the jacket to shorten the cable. I have no clue what it is called or where to get one. I saw one on here a couple times but cant find it.
Any help?
Any help?
if you know that the cables fairly new and shouldn't be bad yet, have you tried checking the adjustment on the threw rod that goes from the clutch arm on the right side over to the clutch basket. If the locking nut backed off from the basket end of that it will have you loosing clutch pretty quick too. A little adjustment there will go a long way on the cable slack adjuster that's on the cable itself.
Edit. Read your reply that came while I was typing. I would wager that this may be your issue. If you do some digging on you tube for how to adjust the rod that would end smack dab in the middle of the clutch basket you may cure your problem. Its pretty straight forward and SEEING how its done I probably a lot more useful than trying to explain it in writing.
Jason,
The adjuster threaded section is pretty far apart. That's all. It works, just I hate threading it back and forth. Be nice to not have to twist the cable end so far. Hence why I want to shorten it up.
As for the videos, I could check it out and see if it helps. So check for harley clutch rod adjustment?
