Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
2013 fltrx issue
Old 04-21-2019 | 08:15 PM
quig95's Avatar
quig95
Stage I
Default 2013 fltrx issue
Good evening everyone, just got my 1st bike, 2013 fltrx and I’m at a loss on finding the issue. I rode around for ~90 minutes today, mix of residential and highway speeds. On the approach to my neighborhood as I downshifted from 2nd to 1st the bike lost all power transfer to the rear wheel. I parked the bike on the side of road and visually inspected shifter ***** and linkage. All parts are tight on linkage, the shifter will not return to a level setting, it just kind of hangs right above the footboard. I was unable to use shifter to get bike back into neutral, but I got it by reaching down and pulling the linkage back until I got the half click of getting into neutral. I pushed the bike the 1/4 mile home and parked it. A hour later I tried again to get the bike to roll in 1st gear, nada, I can put the bike in 1st and 2nd and still roll it backwards and forwards with no gear engagement even with the clutch fully released and getting the bike up to around 3500 rpm. Any ideas? I’m taking bike back to dealer on Tuesday when they open but any advice or possible troubleshooting will help.
Old 04-22-2019 | 04:27 PM
Max Headflow's Avatar
Max Headflow
Dealer is your best bet. My guess would be stripped splines on the clutch or possibly on the shift arm but your symptoms are sketchy.
Yellow Glide
03-24-2022 07:27 AM
dynahead951
05-29-2019 12:59 PM
Jeff2069
08-07-2018 03:08 PM
nathanw
06-02-2010 08:13 PM
1993mooglide
06-08-2009 07:56 AM
Quick Reply: 2013 fltrx issue
