Clutch Q & A
Harley-Davidson
Drive Train Clutch Components
Performance and Technical information on clutches and clutch components for Harley-Davidson motorcycles.
Motorcycle Clutch
The major working component of a motorcycle clutch are the friction plates. The friction plates take the abuse and wear of daily riding. Designed as a consumable item, they wear out and need to be replaced. You can do several things to extend the life of your clutch. They are:
Make sure all components are properly adjusted.
Maintain proper lubrication of your wet clutch. Change your clutch oil at regular intervals. Always use a good quality oil, at the proper viscosity, in your clutch.
Adjust your riding style to eliminate excessive slipping, which causes excessive heat resulting in rapid wear.
When clutch components are replaced, always use the best parts available and replace all worn components. High quality clutch components will save money in the long run.
Frequently Asked Questions about a motorcycle clutch
Q: What type of lubrication should I use in my clutch?
A: Follow the manufacturer's recommendations for viscosity. Use only good quality oils and lubricants. For Harley-Davidson Big Twins, use the HD primary chaincase oil or a good 5-30W oil.
Q: What is the purpose of the oil in a 'WET' clutch?
A: The primary purpose of the oil in a wet clutch is to act as a coolant. The oil in the primary chain case flows around the clutch plates and friction plates, cooling them. This results in smoother clutch action and prolongs clutch life.
Q: What causes my clutch to stick or drag?
A: There is no single cause of a sticking clutch. Some more common reasons for a sticking clutch are:
- Clutch controls are improperly adjusted. Clutch cable is collapsing.
- Clutch spring tension is to tight, spring binding.
- Too heavy an oil has been used in the clutch. A thick viscosity oil can cause the plates to stick, especially when cold.
- Clutch oil is 'worn out' or burnt. The oil has been in the clutch to long, clutch plate wear is excessive causing slippage, or a driving style that slips the clutch. Changing the oil in a clutch often improves the situation.
- Clutch plates are warped. Friction plates or metal plates may be warped.
- Improper adjustment on primary drive chain/belt.
**Q: What about using Synthetic Oils in my clutch?
A: Synthetic oils, by their very nature of better heat resistance and improved lubricating properties, would seem to have an advantage. This is an advantage when it comes to lubricating an engine or transmission, but turns into a disadvantage when used in a clutch. This increase in lubricating properties (they are slippery) can cause an old, worn out clutch to fail. The purpose of the oil in a wet clutch is to cool, not to lubricate. The more 'slippery' an oil is, the more likely a clutch is to slip, resulting in increased heat and creating excessive wear.
While most high performance clutches are designed to work with synthetic oils, it is not recommended that they be used by most clutch manufacturers. Synthetic blends are usually considered acceptable.
Q: What causes my clutch to slip?
A: Some of the more common reasons for clutch slippage are:
- Clutch controls are improperly adjusted. Improper cable adjustment.
- Insufficient clutch spring tension. This can be due to excessive wear or in highly modified engine, to much power.
- Worn or warped friction plates or steel plates.
Q: What causes my clutch to chatter?
A: Some of the more common reasons for clutch chattering are:
- Clutch controls are improperly adjusted. Frayed or stretched clutch cable.
- Burnt or glazed friction plates.
- Worn or warped friction plates.
- Diaphragm clutch spring does not have enough tension. Too flat or worn out.
- Clutch hub liner friction plate rivets loose or broken.
Q: Why is it hard to shift my transmission?
A: Some of the more common reasons for a hard shifting transm
Motorcycle Clutch
