Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
1967 sporster XLCH, 3rd gear jumping, only with no throttle, with throttle no problem
Old 09-25-2018 | 11:03 AM
Cheek's Avatar
Cheek
2nd Gear
Default 1967 sporster XLCH, 3rd gear jumping, only with no throttle, with throttle no problem
What is the problem with my 1967 XLCH, jumping in 3rd gear only with no throttle, with throttle is no problem
Old 09-30-2018 | 08:03 PM
carlgrover's Avatar
carlgrover
My ironhead used to have a catch in 3rd gear when accelerating. Turns out it had a tooth missing on the third gear sprocket. Repost your question in the ironhead sportster section with as much detail as you can and maybe someone up there can help.
carl
Cheek (10-01-2018)
Old 10-01-2018 | 03:00 PM
Zanthamos's Avatar
Zanthamos
Check the dogs and the mating holes on the 3rd gear, they may be worn causing slipping while not under load but when under load they stay put.
Old 10-01-2018 | 03:48 PM
Cheek's Avatar
Cheek
2nd Gear
Thanks, I'll check it out this winter
No H2O
Engine Mechanical Topics
03-25-2019 10:35 AM
Shinner312
07-26-2017 01:41 PM
rojenk
06-24-2015 09:33 PM
firemeat
10-11-2014 05:45 PM
stic2it
05-06-2011 10:24 AM
Quick Reply: 1967 sporster XLCH, 3rd gear jumping, only with no throttle, with throttle no problem
