Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
It feels like it’s grinding, skipping or clicking. I’ve put the bike on a left And checked the pulley was not tight with the wheel. There is some play very very minimal when you hold the wheel and you push the pulley.
Oh wow will do, thanks. All this happened when replacing the battery I have dropped the screw and it may have landed on the belt.
Might be better to say that to start with. If it was on the belt it would not grind but could cause damage to the belt. YES if a stray bolt or screw found itself somewhere it shouldn't be, there could be noise.
Drop the rear wheel, check bearing and check brakes. A screw or bolt on the rotor, pads,or caliper could cause noise.
Hahaha, as I was posting and responding here, I was reading and searching somewhere else, and got my thinking cap on. So that’s when put the 2 and 2 together remembering the screw that I couldn’t find.!
