Inner Primary Sealing Fasteners ???
Greetings All,
I have had the infamous primary bearing failure due to the poorly designed chain tensioners on the 88 twin cams. I have the primary apart and just discovered that I will need to replace the 5 sealing fasteners that hold the inner primary case to the motor/transmission. I can only get a par number for the entire seal kit but I have already sourced the gaskets separately. Does anyone know the part number for the individual bolt or where I can get them without ordering the entire kit?
Thanks
Thanks
hawgriderbc
06-15-2011 09:07 PM
