clutch problem
clutch problem
The clutch cable on my 2012 Heritage keeps loosening rapidly. I can adjust it inside the primary, then on the cable, and after a few pulls on the lever there is lots of slack. The cable is a braided non-stock cable that was put on when the previous owner put a set of beach bars on the bike. After adjusting it yesterday, I went out for a ride. About twenty five miles in, the clutch started dragging like crazy, and the cable had become so loose that there is no effect when it's pulled in. I re-adjusted it several times, and it just keeps loosening with 5 or 10 pulls on the lever. The adjustment is all the way out, so there is no more to go on the cable. Should I replace the cable? Something wrong inside the cable cover? I havent pulled the cover yet... Ideas?
Could be a number of things. Bad inner clutch cable..It's slowly coming apart. If adjusting the center of the clutch brings it back, it is likely a bad throwout bearing. or loose clutch hub nut. It could also be a trap door bearing. Also in some cases the clutch frictions could be coming apart.
rnarus (07-08-2018)
I've never been able to get mine adjusted correctly when doing it by the service manual. Try this:
1. Collapse the clutch adjustment all the way down
2. Adjust the tension on the clutch nut till you feel the level just start to move and lock it down
3 go back and adjust the clutch cable tension till you have about 1/8 of slack in the lever at the tip.
rnarus (07-09-2018)
Comfortably Numb
05-03-2021 12:45 AM
GBogard
05-14-2017 11:46 PM
roach
04-08-2012 04:26 PM
