Baker OD6 with hydraulic clutch exhaust clearance
I have a 2001 FLHT with a 107 and just ordered a baker od6 with the 1/2 wider trap door and I’m installing the factory screaming eagle style hydraulic clutch and I’m wondering about exhaust clearance. I have a rinehart 2-1 pipe and it looks pretty tight, I wouldn’t be against getting another exhaust if needed. Will a d&d fat cat fit, or I was thinking true duals?
Exhaust clearance with od6 and hydraulic clutch
my rinehart 2-1 pipe is close on the stock transmission about 5/8” with the cable operated cover and I’m installing a hydraulic clutch cover where the line protrudes past the forward facing cover bolt. I don’t have the OD6 transmission yet it’s on order.
