Is there ANY yellow metal in modern HD 6 speed transmission?
Uncle Larry (03-18-2018)
Received 49,807 Likes
Most motorcycle gearboxes are constant mesh style transmissions, as such yellow metal components are just too soft to be usable in this except as bushings. I cannot recall if there are brass bushings but I do not believe so. The gears, shafts and shift forks are all steel. The answer to your question is most likely not. Automotive gearboxes are typically sliding mesh transmissions and as such have splitter synchronizers that are usually made of brass or some other such soft metal.
liv2hunt
04-09-2007 09:23 AM
