Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
My 2009 Street Glide has a problem downshifting when hot. Depress shifter and transmission doesn't clunk down into lower gears. After repeated attempts transmission will eventually downshift. Creating a dangerous road condition.
Best regards,
Len
As stated, adjust clutch.. Make sure that the linkage is not binding or hitting anything to limit it's travel.. Make sure that the shift arms are tight on the shafts. Very common for the one on the tranny to come loose and strip do to improper maintenance. HD removed the shift pawl adjustment circa 2000-2001.
Yea, this will be the first time I will attempt a clutch adjustment. Didn't want to cause any problems several days before my ride to Daytona.
Thanks again,
Len
Clutch adjustment takes about 15 - 20 minutes if you know what you're doing and no more than 45 minutes first time. Follow the FSM - not a big deal. Also on a jack to level, you shouldn't waste any fluid.
