mainshaft/clutch assy moves out towards primary
There's no easy answer to that. If it was all fine before you stripped it, everything should go back fine on rebuilding it. Unfortunately you need to dismantle it and investigate. For future reference we have a dedicated Evo section, where you will meet up with more owners, who can help with technical challenges like this.
Dan, the unfortunate truth is that while your statement is true, very few HDF members call by here, as the post count on threads shows. There is more expertise to hand in the dedicated forums.
5 speed transmissions are used on Evos, Shovels and Twin Cams...
This is the transmission forum, this is where this question belongs...
I suggest removing the cover from the right side of the transmission and taking a look at the ball bearing at the right end of the mainshaft.
Boohker
09-06-2017 04:17 PM
