shift peg not returning to proper position after shifting
2005 Harley Fatboy When I up shift with heel peg shift the front peg stays up and heel peg stays down I have to tap the front peg down to upshift again. And when down shifting I have to do the same thing, tap the heel peg down to make font shift peg come up
Disconnect the shift lever from the shift rod, at the transmission end, now move the heel toe levers and make sure they are able to move freely.
Check the shift lever at the transmission, make sure it is tight onto the shaft, no wobble or slipping whatsoever.
If the lever is secure, shift the transmission and see if the lever returns to its centered position. You should feel the spring centering the lever.
Road Star
05-10-2014 09:52 AM
