Clutch Slipping After Installing S&S 551 Cam
I recently had the 551 cam installed to increase my torque. Well it must be working because I can feel the clutch slipping in certain situations. Has anyone else experienced this and what did they do to correct the issue.
I'm thinking this https://www.sscycle.com/products/ss-...twin-clutches/ or should I just go with a heavier spring?
2013_FLHTK (06-03-2017)
2013_FLHTK (05-30-2017)
I used this one: Barnett - 502-00-01004 - Clutch Spring: The alternative for the 37871-98A
Adding this (copied from another post)
I read a lot on the SE spring, if you only install that, people find that stop and go traffic is a work out...
37882-06 (258 Lbs Force) 2006-88”, 2007 thru 2010-96”
37871-04 (298 Lbs Force) 2004-05 88” and 2010 Limited
37871-98A (320 Lbs F) 1998-2003
37807-03 (364 Lbs F) 2007 thru 2010-103 ”Police"
37951-98 (386 Lbs F) Current SE
The following 2 users liked this post by fordhd2005:
Mac daddy 103 (05-30-2017),
Max Headflow (05-30-2017)
Well I'd go with:
Looks like your bike uses 37871-04 (298 Lbs)
I think the Barnett light spring is the same as the 37871-98A (320 Lbs F) 1998-2003. It might work I use this stock early spring in a 07 FLHTC that's been built to a 103 but use a Barnett Kevlar clutch frictions. It works well. I wouldn't use the Barnett heavy as it's 480 lbs (Tested and use in another bike)..
I would scuff up the steels with a little 80-100 grit while in there as they can glaze over.. If you got access to a bead blaster use it..
The following 2 users liked this post by Max Headflow:
2013_FLHTK (05-30-2017),
