trouble finding neutral and bike lurching after clutch work
Meant to say belt replacement, not clutch work in the title.
on my 2006 Softail Deluxe, I'm having trouble finding neutral, and bike is lurching at a steady throttle, most noticeable on the freeway. The belt was replaced and I was informed that they had trouble getting the clutch back in.
is the lurching clutch related?
please advise,
Thanks!
please advise,
Thanks!
Last edited by tat2dancer; 05-26-2017 at 08:33 AM. Reason: Meant to say belt replacement, not clutch work in the title.
It's most likely they strewed up something if the clutch doesn't work after belt replacement but did before.. Clutch adjustment is the first thing to check.. Primary level also. The lurching at steady throttle could be something else.. Belt alignment? Still it could be the clutch.. They usually screw up/slip under power if adjusted wrong. Did the say what the problems was with getting the clutch back in?
tat2dancer (05-26-2017)
