Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Starter went bad so I replaced it today. Tested with primary cover off and all was good. Put the cover back on and all I'm getting is a spinning noise. Any ideas?
Did you fold the safety tab over on the jackshaft bolt?
The other question would be "is the jack shaft coupling in the right way?".. IIRC the snap ring goes toward the starter. Also make sure that the bolt is tightened correctly.. Not too tight..
