"self lubricating" chain?
RE: "self lubricating" chain?
Okay, get a jack. Put the bike up on the jack so you can rotate the chain freely. Bike in neutral obviously. Spin the rear wheel and spray the chain at one spot until the chain has gone around at least once if not several times. Get a clean rag and grab the chain with the rag and spin the wheel a few more times until the chain looks clean. Clean all the excess lube off the wheel as well. Repeat this action as needed depending upon how much you ride. When I rode 100 miles a day I would do it once a week. It will greatley extend the life of your chain to keep it clean and lubed. I never had a "self lubricating" chain. Ifthe chain is real dirty spray it with wd40 first to clean it, use the rag to get off the wd40, and then lube it and wipe off the excess. I used to use pj1. I also had a friend who swore by using clear silicone to lube his chain. I never tried it but I never knew him to have a problem...
