Is it normal
Is it normal
First off I run hd primary fluid in the primary and gear lube in the trans I just pulled my primary down to replace the inner primary seal and I'm pretty sure I could smell gear lube on the drain plug and in the fluid. Is it possible gear lube can migrate to the primary maybe it runs up the clutch push rod? Is this normal or do I have something going on I need to address?
lomoman
09-10-2007 05:08 PM
