clutch jam nut
Make sure you loosen the clutch cable up to where there is no tension at the clutch lever. Use a 1/2" drive 11/16th deep well socket and if you have a breaker bar, use that. Otherwise a good ratchet. Position the handle in the 12 o'clock position. Look at it for minute and vision that bych owes you money and keeps making stupid excuses for not paying up. Once you feel the anger coming on, use the palm of your right hand and slap the crap out it using a short direct follow through swing. If that doesn't break lose, put a 5/8 socket on the nut and just tap it gently with a hammer. Then repeat the bych slap process.
