Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Looking to upgrade the Primary chain Tensioner
Anyone done it and what were the results ?
Gus is online now Add to Gus's Reputation Report Post Edit/Delete Message
I installed a self adjusting primary chain tensioner on my 02 heritage. It kept the primary chain to tight and wore out the clutch hub bearing, causing the clutch to wobble. With a wobbly clutch it shifts hard and you can't find neutral. Like bwoltz said if it ain't broke.
